Fob key repair/replacement
If you have a fob key problem ie: buttons not working properly / not at all try this
1: remove battery, then bend small side prong up a bit so it no longer sits at the side of the battery but on top of it when re-fitting, chances are it's no longer touching the battery..
2: if step 1 hasn't worked buy a new fob replacement then carefully cut the rubber down the side of the transponder remove then fit into your new fob key ( use some blu tack / PVA glue to stop it moving and lessen the chance of breaking it ) and swap the circuit board and the key end..
