Keeps Shuffling Same Songs Over And Over
Hi there,
Just wondering if anyone else is experiencing the same problem with audio shuffle.
I have a usb stick with about 10 albums on it and I have it set to 'shuffle - all'.
After a while I noticed that i've listened to the same 12 songs over and over and none of the other stuff on the stick, so I started to click through 'next'
Sure enough, it's shuffling the same 12 random songs in order over and over again.
If I pick a different song not in those 12 and play it, sometimes it shuffles normally but as soon as one of those 12 comes on, it goes back to playing in that order!
Is this a fault or has anyone else noticed this? It's driving me insane!
Lee
It maybe the way you have set up the folders on the stick, also check to make sure you have not set the radio to shuffle just one folder and not the entire stick, check the Ford audio manual supplied with the car for the correct way to lay out the folders, or you could try putting all the songs in one folder and see how that goes.
Hi there,
I have it set to shuffle all, but it's laid out as 10 seperate folders (one for each album).
I'll try putting all the songs directly on the stick and not in folders.
Many thanks for the suggestion!
Lee
That should work. ^_^ You will probably find all the 01 songs will be first on the stick and 02s next ect, this won,t matter if you only want to shuffle songs.
You're a lovely mover Lenny. :P
Gotta Love Pulp Fiction,
just watched it again yesterday
