Removing Rear Lights Focus 5 Door Hatch 2012
Hi
Can anyone help:
I have read the instructions and can see the wing nuts that have to be removed.
These are extremely tight and I cannot undo by hand - is there a knack or something.
Also it says detach clip - what and where is the clip?
I dont want to break anything by using force.
Regards
John
I've removed them from 2 MK3 Focus's now, they're too tight to do by hand so use some pliers.
Are these the same type the mk1 had a plastic not with a metal bolt through them ? I broke two on the mk1 they were on so blooming tight
Seems like they are - it is a plastic nut with a bolt through.
John
Thanks I just did not want to use pliers if there was a simple knack to it that I was unaware of. can you tell me what this clip is the manual refers to.
The only picture is of the wing nuts?
Am I right to assume I just undo the wing nuts and the light fitting will pull away from the car so that I can undo the wiring plug?
John
