Clutch Pedal Return Spring
16 replies to this topic
#16 soulman123
soulman123
  • 213 posts
  • Name: dean
  • Ford Model: 1.8 ghia petrol
  • Year: 2004
Posted 10 April 2013 - 06:12 PM
That sounds like a horrific job.
I know this will fail on mine at some point and will end up trying miserably to fix this. At least I have learned some good tips here thanks to all for sharing.
#17 clarky100
clarky100
    Newbie
  • Pip
  • 1 posts
  • Name: Dave
  • Ford Model: Focus 1.6 Titanium
  • Year: 2006
Posted 18 April 2013 - 09:45 AM
I managed to fix mine yesterday. Bit of a nightmare, but this is how i did it. I managed to use the coin trick only, but I used 5Ps instead of 1Ps.
Outside of the car, I got one end of the spring attached to something sturdy so it hangs down. Can be anything as long as it doesn't move as you will need to pull the spring down.
Then i got a spring puller and attached this to the other end and pulled the spring firmly down. With it being pulled, I then inserted 5p pieces on each side of each coil. so there were about 25 or so. You need to make sure you have coins either side of each coil on every coil. This i found stretched the spring long enough.
I then inserted the shorter end of the spring to the bulk head, and with the spring stretched  the longer bit went in nicely on the pedal hole. Dont get me wrong, its a sod to get to and access is tight but if you get a decent torch so you can see where the 2 holes are you can manage it.
Now, i was expecting the coins to drop out when the pedal was pressed, but this didn't happen, so I had to remove the coins with a pair of long nose pliers. you need to give them a bit of a yank, but they do come out, and then the spring is in nicely and the pedal no longer has play in it.
When I first did this I took the advice of an earlier post of using just 15 5Ps and seeing if this would be enough, so this took a bit of time. I would say if you start with every coil with a 5P in each side, it shouldn't take long at all to do.
Hope it helps.
