Driverside Window
So recently ive noticed that if i open my driverside window and then do it up it goes up automatically... this is normal but its started to go to the close posistion to immediatly reopen again???
any one got any ideas why its started doing this?
its not a feature ive seem before... I can only close it if it stop the automatic close my closing it in increments
Focus mk2 titanium 09
It's an anti-trap feature.  Basically if you stick your arm through the window and try to close it, it'll bounce back rather than cut it off...
This works based on resistance so there may be something making the top of the window stiff.  Wind deflectors are a pain for causing this but I assume you don't have those?  Cleaning and lubricating the window seal is the next thing to try.  If that fails, you may need to reset the auto close function.
The Quick Up/Quick Down functionality is part of the Comfort (4-electric) Windows system. The Comfort Windows system has pinch protection. If the force that is needed to close the window is higher than expected the window will re-open.
The problem you are experiencing can have 2 different causes:
1. The Force needed to close the window is actually higher than expected. This can be caused by a mechanical issue like for example a worn window mechanism or deteriorated window seals window seals.
2. The windows are not properly initialized. By performing the windows initialization procedure that is described in the owners manual the system detects and stores the exact end positions of the windows. If not properly initialized the window "thinks" that the window is still open while in fact it is already closed (or vice versa).
