Dipped beam fuse
Where is the dipped beam fuse on a Ford 07 s max ? Need to uprate fuse as want to replace headlight bulbs
Fuse to low beam s max
I wouldn't put bulbs in that take more power than standard the wiring won't take it
there is no fuse as such, the bcm module controls the low beam and if detects a short circuit , switches off power.
also if you put higher wattage bulbs in , that will also give same outcome.
