Focus C-max 1.8 petrol misfire and smoke from exhaust
Hi all, from few days i have really bad problem with my C-Max, first i tested car and error pop up P0304 which is misfire on cylinder nr 4 the i can tell that car is shaky, from low gear is just you can see it how bad it is, i have change ignition coil, but still the same problem, and now i have lots of smoke from exhaust and the smoke is white, whole exhaust is shakes up bad. any ideas guys?? please
Possible causes
  • Faulty spark plug 4
  • Clogged or faulty fuel injector 4
  • Faulty ignition coil 4
  • Fuel injector 4 harness is open or shorted
  • Fuel injector 4 circuit poor electrical connection
  • Ignition coil 4 harness is open or shorted
  • Ignition coil 4 circuit poor electrical connection
  • Insufficient cylinder 4 compression
  • Incorrect fuel pressure
  • Intake air leak
