dab ariel
Can anyone tell me which is the best dab Ariel to usr in my 08 mk 2 focus
any help
thanks
mickj
THIS is the one that came with the Focus originally (if it was fitted with a DAB radio in the first place)
Whether or not it's the 'best' is open for discussion, though!
I've had good results with a https://www.ebay.co.uk/itm/Universal-DAB-Digital-Radio-Glass-Mount-Aerial-Antenna-Amplified-SMB-CT27UV70/371313480374?epid=21017008621&hash=item56740212b6:g:GuMAAOSwHoFXreem  on my merc, allegedly the Ford unit sticks the power up the coax to make this one work
I used the glass mounted one with a Sony Radio
the reception is perfect
I've fitted a Pioneer powered DAB (windscreen type) aerial to mine and I'm generally pretty happy with it considering it only cost about £14.
I've noticed however, that in certain areas the signal will drop out where as when I've been in the same geographic area in newer cars that have a factory fit DAB, they've managed to hold onto the signal for longer/without losing the signal.
For general use in areas with a strong signal I can't fault it, not when a really good powered external DAB aerial was over £60.
