MK8 Fiesta - Permanent Live Fuses ?
I'm trying to hardwire in a dashcam and was wondering which fuses under the glovebox are permanent live as I don't have a multimeter to check.
If you have a cig socket normally that’s a perm live. I have my thinkware F900 pro hardwire to the cig socket fuse as perm live.
You can check by putting in a cig usb charger socket into it and seeing if you can charge your phone whilst engine is off. My one has a light that turns on when I connect it into the cig lighter socket.
Sent from my iPhone X using Tapatalk Pro
I think I remember reading the accessory sockets (cig) only stay live for 75 mins after ignition is turned off.
Looking at the fuse chart, I would guess that fuse no.5 lock/unlock would be live at all times, but that's only a guess without checking..
  • 3 weeks later...
Just to confirm, I've now hard wired my dashcam, and fuse no.5 is permanently live 👍
Did you go for single or dual dashcam? And has it effected the start /stop?
Just a single dashcam, a nextbase 512g that I've had a couple of years. Start/Stop works fine for me, but It's probably too early to say if it affects start/stop, but will definitely keep and eye on that.
  • 4 years later...
any issues with this? i have a Nextbase 522GW that i would like to use the parking mode with
