SMax engine fault? Engine failure warning with some foggy/mist at rear of bonnet?
So twice now on a long journey our SMax has cut out with an engine malfunction warning. The garage looked at it after the first occurence and basically came up empty.
It happened about 2-3 months ago, and happened again (second time) over the weekend (after 2hrs of driving):-
- Engine cut out/stopped and an Engine Malfunction was reported on the dash.
- A misty/foggy whitish vapour could be seen coming up from the rear of bonnet at the bottom of the windscreen.
- Engine is not over heating (at least according to temp gauge).
- Engine would restart but would cut out again randomly (even at idle) with Enginer Malfunction.
- Engine could then (at times) be lumpy. eg: When driving it onto rear of recovery vehicle it was lumpy and on the verge of stalling.
- Once cool/later it seems fine again, and indeed is perfectly drivable.
To me, the small amount of misty fog coming up at the bottom of the windscreen/rear of bonnet must surely be a significant bit of evidence as to the cause?
Any suggestions from knowledgable folks?
Note: On the second occurence of this issue, the coolant level was very low! It was down to just an inch or so. I can't say if this was a recent thing or been happening over a long period. But the car has been regularly service and schecked after the previous occurence of this problem a couple of months ago.
So it could well be coolant plays a part in this matter? eg: Maybe the mist/fog when it happens is coolant?
