rear lights where to get
hi there, so my wife smashed the drivers side rear light unit and need a replacement ford are wanting £250 its for a ford focus titanium navigator any advice where to get one cheaper i have asked a few places and they want the ford part number ant help its on a 14 plate
thanks
thanks
eBay is your friend.
https://www.ebay.co.uk/itm/Ford-Focus-Driver-Side-Rear-Light-Mk3-2011-2014/222999426328?hash=item33ebcd3518:g:sUAAAOSwO9RbD8CZ
£35
cheers just messaged him as need the led version
The Ford part number is 1825319.  But most people selling used ones don't seem to list them using that number.  Not sure where Ford got £250 from though, as they're £100 cheaper from Arnold Clark on ebay!  https://www.ebay.co.uk/itm/Genuine-Ford-Focus-MK3-Rear-O-S-Tail-Light-Lamp-Cluster-1825319/252771346567?fits=Car+Make%3AFord&epid=1648472935&hash=item3ada58a887:g:yUgAAOSw32lYo6qE
The one you've linked does look like it's got the LED strips, I think that's the only difference between base spec and higher spec lights.  Also I assume it is the pre-facelift model and not and early '64 facelift.
yer its on a 14 plate thanks, local garage priced it up from trust ford
also found this will this do cheers
https://www.autopartspro.co.uk/johns-7937255
That looks right but may be inferior quality compared to the genuine part.
cheers mate ordered today fingers crossed it the right one lol also when i accelerate i can her a grinding noise any ideas what it might be
Would need a bit more info to diagnose that really.  Which engine and mileage?  Does the noise from the engine area or could it be brake/wheel bearing related?
1.5tdci 50000 miles think is wheels only makes it when accelerating and stops when you brake
It's probably due a set of front pads & discs at that mileage, discs might be badly corroded on the inside.  Best to have a garage check it tbh.
yer going in on thursday how much should  the brakes cost roughly at a local garage
It might not be that, I'd say around £150 for discs and pads supplied and fitted at an independent though.
cheers aye could be owt ta
