Another "odd engine noise" query
Focus 1.6 2010 (100HP) seems to have developed a noise from the engine recently. It's hard to pinpoint when it started but it could have been since a cam belt change last year which was followed fairly closely by a power steering pump pipe leak/failure (now repaired). Engine has done 56k and oil is changed every 12 months / 8k. Water pump was not changed with the belt.
Noise isn't so noticeable in the cabin but more so when driving with window open near something that reflects noise.
Anyway, when coming off the throttle, e.g. to change gear, or when engine braking to traffic lights, (off throttle, again), there is a noise not unlike rattling a can of dried peas really quickly. The noise seems to go away under acceleration and at idle, which makes it hard to detect. With the bonnet open and engine revved, it also isn't so obvious.
At idle, there does appear to be a bit of a "wo-wo-wo" noise but it's not overly obvious although it can be worse when the engine is first started in the morning.
A mechanic mate of mine listened to it being revved and said there was nothing really wrong - maybe just a bit of tappet rattle down to wear.
Do these lumps get a bit rattly at these mileages? Otherwise, does anyone have any suggestions?
Thanks for any help
