lowering springs
Hi
Has anyone fitted lowering springs to a fiesta mk 6.5 is it an easy job?
Thanks in advance
Anyone?
My dad did remove the rear springs on my car when we were doing the rear drums to ST discs conversion. It doesn't look hard however I haven't done it myself to say it's easy or not
Very easy on the Mk6, rear springs just drop out once the lower shock bolts have been removed and the beam swings down.
Fronts are the same as most cars these days, strut needs to be removed, then spring compressed and top nut removed.  Lift off top mount, fit lower spring (don't usually need to compress them) and push the top mount on while fitting the top nut.  Then refit the strut to the car.
Thanks Guy's ill post a couple of photos on Sunday if all goes well
all done
You can see the difference there. Also noticed you put the ST spoiler on.
Good job, looks cracking!
Thanks Guy's my son is really please with the way it looks and drives might even do my focus now
