air con
can some one point me t the low pressure service port is on a mk2 fl please. in the haynes manuel it shows the high and low but doesnt tell you if its the front or the back one
Low is the smaller of the two
the pipe you mean ?
The connector, high and low have different sized connectors so you cant connect air con machine hoses on wrong way
What you trying to do? Put some refrigerant in?
i want to test it see if there is any in it and then fill it
Low pressure is the larger one, right at the back near the brake fluid res on the mk2 iirc, awkward position tbh.
cheers will be looking later.thanks every body for the help
