Mk2 headlining
Hi all,
Would the headlining and pillar trim from a mk2.5 st225 5door fit a mk2 ghia 5door? I want to upgrade to the black trim and headlining.
I have found a mk2 headlining and mk2.5 trim, and I really want to use the two lots of parts to make one set. I can't see a lot different with it but thought I'd ask before parting with cash for both if they won't work.
Many thanks Mike
I have fitted it so like stoney871 says 100% compatible. Doesnt matter facelift or pre facelift still intercangeable.
Yunii
Try and get the front submarine light as well if you haven't already got on as the wire to connect it should be tapped back to the loom.
I used my original loom as you don't need to go back to the fuse box to swap it over.
