Please help - DPF Code P2002
Hi, apologies if this is in the incorrect place on the forum.
I'm looking for some help. I've recently picked up an 06 focus 2.0 tdci and I've had limp mode come on. I've been to the garage who have said code p2002 is showing which is essentially the DPF. The thing is, the DPF is brand new including the pressure sensor and all of the wiring.
I believe p2002 means: Trouble Code: Diesel Particulate Filter Efficiency Below Threshold Bank 1
A regeneration was done and the light reset, within half a day it was back. Same code.
Went back to the garage, they have suggested a new EGR valve. One was installed, light reset and on my way I went. This lasted a day, the light returned.
Does anyone have any idea of what this could be? I'm having a new fuel sender unit installed as when I bought it, I knew it needed one.
Also in the times where the car was running OK, cruising at 2000rpm presented me with a slight hesitance/judder. Enough to rock me back and forth In my seat.
Any ideas anyone?
Thanks in advance!
