Wheel Hub Nut Torque?
What torque should the wheel hub nut be torqued at? I've been told 255Nm, is this right?
I've got a clunking noise when driving at slow speeds, and wondering if the driveshafts are loose. I have no play within the wheel, no noise when on full lock. though find slight play if I go under the car, I can slightly move the driveshaft. Do they slide in and clip? or just push in?
Clunking noise at low speed for me was the anti roll bar bushings. Silicone spray solved, might be worth a shot.
