General
how to connect the passengers electric window to the drivers door switch. Which wires are required.
The passenger switch is damaged but the drivers door has a two way switch.
2006 ford fiesta 2 door car
If there’s an issue with the wiring that makes one side not work then that makes a break in the circuit so that will result in the switch not work on both sides, if you replace the faulty passenger window switch then that will resolve the issue
