2006 ford focus auto 1600 petrol wiring harness access
😍Hi Guys and Girls,
Can you Please tell me how to Access the Reversing  light Harness, on my ( 2006 Ford Focus Auto 1600 Petrol),?
It as just One Reversing Light,
Reason I ask is, I want to install a *Wireless Back up  Rear View Camera* and a Monitor.
I need to connect the  Camera to Reversing Light Wiring, which is the tricky bit.
So if you great Guys and Girls can Please guide me to  the Wiring Harness.?
Thanking You All.
Rob
Just tap straight onto the wiring at the reverse light.
Reach behind the light unit and remove the bulb holder with a quarter twist.
Sent from my SM-G965F (S9+)
If you follow the wire colour i believe it heads up on the N/S in the boot behind the trim too, this is where mine is connected. Multimeter recommended to check!
16 hours ago, robby12345 said:
😍Hi Guys and Girls,
Thanking You All.
Rob
Hi Rob
I've created a guide on fitting a second reverse light to a mk2.5 focus, in the process I've spliced in to the original reverse light loom inside the boot panel, the process is exactly the same on the mk2 and there's fellow mk2 owners whom have post on the guide stating the colour of there reverse cable positive,
On the mk2.5 it's green&yellow,
I've also created a reverse camera fitting guide among the list see link below:
