Fog Light Not working
I cannot seem to find anyone that had this issue  , ok here goes :
I took the fusion 2003 for an MOT yesterday , it failed because of the rear fog  light is not working ( I believe its the only fog light on my model ) , at some point water had got to the contacts and possibly caused the problem
It transpired that the bulb is fine and the fuse is fine (tested bulb in another hole) . I put a  fluke meter on the bulb contacts and on the wire terminal of  for the fog , there is no voltage going to it .
The fog light indicator works on the dash , if  I take out the fuse , the light goes out .  I assume the fog light must be on a relay , yet there is no 'click'  so maybe relay is faulty ? However according to this page from the Haynes manual here , there is no fog relay
Can anyone help? Perhaps there are wiring diagrams available for this
Forget it , the MOT garage got the lights wrong , they said the nearside foglight weren't working , it transpired this is the reverse light - doh
