2012 mk3 titanium x drl wiring
Hi guys. I’ve just bought some extra drl’s with switchbacks.
My headlights have the standard drl’s in them and I want to wire the new lights to them directly. Does anyone know which wires on the headlight multiplug I’d need to tap into??
Thanks in advance
Paul
Thanks in advance
Paul
+1 on this.
Trying to figure this out along with how I could wire some lights into my non existent sidelights as rear lights are also LED on my car.
These switchback drl’s are a weird setup. The indicators on them won’t work unless they’re constantly powered. Wire them up to the battery and the drl’s don’t go off at all.
Btw the indicator wire on the multiplug behind the headlight is the blue/green wire top middle of the plug.
If you are using the battery route you can buy a drl controller. You tap the yellow to indicator wires and the white to low beam so the drl dims when the headlights are activated very simple setup.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F153210516124
