Sync 3 Map Update Issue
All updated succesfully at last.
The map update after unzipping leaves you with 3 Files -
SyncMyRide (22.1Gb), autoinstall.lst (33Kb) and DONTINDX.MSA (0Kb).
First half of the update took 30 minutes, 2nd part 38 minutes, as happened with other people no xml was generated at the end.
Checked the screen after re-starting again and came up F7 as it should.
Hopefully next time there is an update it might take me less time than it did this one!
Thank you to DG97 for the advice again - cheers Paul.
Really wish Ford updated their instructions on the map updates to stop saying you get an xml file when they know you don’t.
I’d have saved myself a fair bit of time if I knew that the instructions were out of date.
