MK3 Powershift Automatic oil change
Hi everyone
Do anyone knows when I should change oil i my automstic powershift gearbox its already 33k
Anyone has any expernce in that
Which power ***** is it ? What engine?
1.6 petrol base , 6 gear powershift mk3.5
There's not transmission oil change interval, but if you want to do it, it's 75w Fe transmission oil. 1.7litres. there is a drain and refill/level plug. The level plug is a bit awkward to get at. I use a bit of hose slightly smaller diameter to garden hose with a funnel on the end to pour the fluid in.
I was thinking to do this at dealer , just curious how much will cost me 😄
Hi, I think the service interval is 3 yearly and the best done by dealer as new oil has to be pumped through. Gearbox oil filter also needs changing at the same time. Likely to cost around £200 at the dealer
Although it sounds expensive when I bought my car which is power shift the box was still under warranty after a rebuild because one of the previous owners missed an oil and filter change the invoice was for £ 1600. 😑
That's the dct450 box. The 1.6 n/a engine uses the dct 250 box. Just needs a simple drain and refill .
https://www.opieoils.co.uk/p-69412-castrol-syntrans-fe-75w-fully-synthetic-car-gearbox-oil.aspx
