errors on forscan
I had a  Blocked DPF filter error code 2452 and car went into limp mode  a Ford mechanic told me to change change the Particulate Matter Trap Differential Pressure Sensor  which got rid of that code and I now have 2453 code car runs fine
Im using Forscan and now with particulate matter trap differential pressure sensor circut range/performace
on running DP_DPF only stays at 0.2 psi
When I fit the old Sensor the code 2452 code returns
On doing a Google some say The fuel filter could be clogged  I would appreciate some help here as I dont want to buy a new DPF if the fault is elswhere
car has just over 10000 miles
I have washed out the exhaust but the water was very clean
