Ford FocusError Codes
My Sons Focus 1.6 TDCI has these errors
P2453
P242F
U0073
P193B
P1936
P1934
P0500
P1935
U1900
Any ideas please ??? All started with P242F and gone from bad to worst
P2453
P242F
U0073
P193B
P1936
P1934
P0500
P1935
U1900
(Not having used my code reader since I bought it a couple of years back) I’m assuming those are the codes straight from the dash, you’d be better buying a modified ELM 327 and using one of the free software packages like Forscan but take a look here, it might help with ‘some’ of the codes  ....... https://www.engine-light-help.com/ford-check-engine-light.html
Hi
Codes are from Forscan with OBD11
12 minutes ago, unofon said:
Hi
From the Forum .....
Quote
are these codes recent if not clear them and see what comes back
From those codes, with no other info to go on, it looks like the DPF is blocked, due to low eolys additive & possibly a dodgy pressure sensor/pipe.
And the dash cluster needs repair, is it a prefacelift model?
Thanks will check the eoyls  before i fit a new DPF  Have changed pressure sensor but faulty one from ebay  only geting .2kpa  getting a high  pressure reading of 30 kpa now
Pipes seem ok
Dont know what model as its my sons 2006 model
