Seat tilt clips
Hi, both of the clips that you use to tilt the front seats forward have broken. Im guessing its a wire inside as the plastic clips are still attached. Is this an easy fix?
they break at the plastic clips most times remove the plastic clip and check there :smile:
do you mean the plastic bits you pull up to release the front seat tilt catch (3 door cars). on a friends fiesta they both broke. they were both replaced and both broke again after a while. I removed the broken bit of plastic and tied a looped shoe lace around the end of the cable that comes up out of the seat (it's like a bit of bicycle brake cable in the seat back). Doesn't look pretty but does the job.
it would probably have been easier with cable ties but I thought they would cut into the hand more than a nice wide show lace
Quote
those plastic bits are the weak link in the seats i like the shoe lace idea
