Mk7 facelift window problem
The drivers side window will only goes down about 1cm and stops is there an easy fix?
This happened to me just last weekend. i just kept on playing with the button and it eventually started working correctly again.
Might be somethink to do with the freezing cold weather?
Had to reset one touch again as it would not go up on its own.
It worked 😂😂 thank you
