Front and rear brake disc sizes of a ford focus 1.6 estate 05
Hi I've roughly measured the brake disc diameter of both without taking the wheel off, and both are 278mm can anybody confirm this is right?should of took the wheel off so I knew for certain myself some break discs are 265mm you see may be estates are different?
Can anybody help me with this?
I always use these when trying to confirm technical part info.
https://textar.com/brakebook/
http://www.bosch-automotive-catalog.com/en/vehicle-search
I know the focus front brakes are 278mm as the mk6 fiesta ST has the same size front discs. One thing though is I think it varies depending on the engine.
