Please give me your settings
Hi all
If you have a fiesta mk7.5 that has 17" wheels from the factory please send me the circumference setting that is set using forscan...
I've found out sausages placed in the middle of the oven on a gas mark setting of 6 works well and doesn't burn them too badly 😄
Ok I'll get my coat..................
  • 3 weeks later...
On 2/15/2019 at 5:29 PM, liamstears said:
Hi all
Checked forscan but i have 16" which is 1835 there are two settings below which are 1840 and 1875 but whether these are for 17" are anyones guess
You'll get away without changing it. The difference is so negligible that it's not worth the hassle.
All Speedo are under by 5mph anyway,
Check speed dial compared to sat nav to see this.
And the overall circumference of the wheel will be the same just more rim instead of rubber sidewall
AAEAAQAAAAAAAALWAAAAJGJhMjZiMzNjLTE4MTUtNDhmYS05ZmMzLTk1NmFlYWU3MjY2MA_zpstyl1pnma.thumb.jpg.7becfd0fe6c6decab0f8fae31912d416.jpg
Just put 205x40x17 on my car from 195x50x16 and it has made no difference to the speedo still reads 30 when the sat nav says 28mph
