Folding mirror retrofit
Has anyone fitted folding mirrors to a 2017> ST-Line?
I know i'd need the switch and probably mirror bases but is the wiring in place needing it to be activated or would a new harness be needed as well?
Can't tell you if the wiring is there on the Fez but if it isn't then it's a rather big job. There is a topic on the Focus forum where someone did it from scratch, I think it was @chris_wynne
Im not sure about the wiring either, but I'm pretty sure it needs programmed. That could either be officially at Ford, or using ForScan.
