Forscan Help
I’ve just updated to the latest edition of Forscan.
I have the extended license, so I know that’s not the problem; however when I try the programming screen instead of the new style list of items that can be either enabled or disabled, I’m still seeing the hex codes. What if anything have I done wrong or what am I doing wrong please?
Any help would be much appreciated.
Does work like that for the Mk3?
If it does then then I’m sure some modules are doubled in the list ie 2 BCM modules, one has the Hex long coding and the other has the enable/disable drop downs.
it may be under Central Config
Thanks, I’ll have another look.
