MAF Sensor wiring
I'm trying to have a play around with the MAF sensor by modifying the signal the the ECU receives, but I can't quite figure out the pin out. There is nothing in the haynes manual about it.
I think it should have a 2nd ground for the chassis and ECU. Anyone know why pin 4 is 14.4V?
4 is the ignition feed - 14.4v is alternator charging voltage so that's fine.
2 is earth as you say
1 is PCM reference (5v)
5 is MAF signal
The IAT is separate on this engine hence the empty pins.
Thanks for the reply.
Shouldn't the MAF signal be from 0 to 5V though?
