Power loss at 60mph
I have a 2013 Zetec S 1.0 EcoBoost, when in 3rd gear and above once I reach 60 I feel a power loss, could anyone point me in the direction of what to look for? Thanks
You need to check to see what codes the car is throwing? Did the engine light come on? Are you using MyKey with a maximum speed imposed?
air filter ? spark plugs ? it should be noted also that some high mileage ecoboosts suffer from low fuel pressure at some point due to high pressure fuel pump tappet needs replacement
Does power kick back in after a few seconds? Sometimes if I'm flooring it turbo lag is very noticible in third.
