Washer Jet Problem Anyone?
Basically you press the button on the end of the windscreen wiper stalk, the motor wrrrrrrrrrrrrs and you get a dribble of water coming out of the jets, great for washing your bonnet but not a lot goes on the screen. :unsure:
Had this problem twice now 1st time I thought it was due to the cold weather and the bottle or pipes freezing up. :angry:
Today I thought maybe there is a filter that has got clogged up and needs cleaning. :(
Whilst I had the bonnet open I checked the pipes and noticed it curls back on itself as the bonnet closes. I pressed the button whilst the bonnet was up and whooooooooooooooooooosh water at full pelt coming out of the jets. :o
Closed the bonnet and noticed the pipe bends cutting off the flow slightly. :unsure:
After moving the pipe around I’ve now closed the bonnet and once again the washer jets really work spraying water right up the screen. :D
Might be worth checking yours if you’re having a similar problem B)
The tube that goes from the jets to the tank often get squeezed between the hinges on the left side of the bonnet when opening/closing, i believe this is quite a common problem.
As above tube pops out of a clip belowe the hinge and gets pinched.
Yup. I had exactly the same problem. Fixed it by opening and closing the bonnet. Was due to the tube being compressed in the hinge.
