Hozelock Problem.
I have had Hozelock for years and just had a new one i seem to have a commom problem.
Where the feed from the tap outside (small pipe with 2 hozelock clip on ends) which fits onto the reel in the middle keeps poping off and tried another end but the same,seems a common fault with water pressure and the turning pops it off.
Anyone on here got any sollution to this,looking into a brass swivel elbow but trying to find one that will fit the Hozelock screw end onto the reel,any help is great as i have a new complete new hose that i cant use right as i have to pull the hose out then walk back to turn it on which still sometimes still pops off on pressure.
When i look at the connector it says it a 5/8'' and i was trying to convert it into a 3/4'' or 1/2'' so easy to get a swivel brass fitment,2 links below.
..Mine it the grey on but pressure and it turning at the same time pops it off.
https://www.ebay.co.uk/itm/Hozelock-Inlet-Tap-Adaptor-Grey-Connector-Hose-Reel-Cart-2169-For-Gardening/323680715749?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
Wanted this one as then the end dont turn the knucke does so wont pop off.
https://www.ebay.co.uk/itm/Brass-Revolving-Elbow-3-4-to-Snap-Fitting/281078237522?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
Or put this on if this will fit so i can make it to a 3/4''
https://www.ebay.co.uk/itm/5-8-x-1-2-x-3-4-Outside-Tap-Adaptor-Old-x-New-Garden-Hose-Connector-Thread/121485671790?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
The nipple bit has probably worn, is the o-ring still there, intact and soft/pliable?
Standard tap screw connectors fit (replaced my parents one) the old reels, unsure about the new ones.
Well sent Hozelock a e-mail asking about it so they sent me a new spindle with the new end on so thats a spare as i have got all brass connections now and seems ok.
I did try another plastic end and still did the same but the one i was using was new anyway so it was mainly down to water pressure but the brass end is A1.
Shouldn't worry about it too much, there will be a hosepipe ban soon anyway, as per..
