Help!!!
HELP!!!.
Having major issues with electrics. This morning wound drivers window down. Since then unable to wind window up Passenger side window does not work at all. Brake lights and reversing light do not work Key Fob is not working, but central locking works with key. Have checked/renewed fuses in both boxes, changed relays about. Removed passenger side fuse box and checked pins ( no damp ). Now at a loss to what to tr next. Help appreciated. Thanks.
Ford Focus Mk2 2005. 1.6 petrol
Sounds like you need a new battery!
Get it professionally tested under load
Thanks for reply. Battery is new showing 12.4 volts . Charging at 14.2 volts.
 Today brake lights blowing fuse even without any bulbs in the circuit. Headlights sometimes blowing the fuses; Think I may require a new GEM.
