Cold starts,
IHi everyone,
has anyone else had this problem, really need some help, I have a ford Fiesta 2010 plate , recently this has happened, been to one garge nothing comes up on the machine , then took it to ford they don’t know yet,
The Car occasionally exhibits poor starting in the cold weather.
When the low temperature light is on the car struggles to start with the revs being too low (below 1000rpm) and juddering causing it to cut out.
As if the choke on cold mornings is not active or idle control valve is not functioning correctly.
Possibly air/fuel mixture is not working correctly.
Please investigate to diagnose this problem.
Once the car is warmed up there is no problem.
The battery and coil pack were changed recently, but the problem still happens on cold mornings
any one else had the same problem?
