P006A fault code
Hi all. Can anyone help? Got an engine malfunction warning on my 14 plate 1.6tdci econetic. Car goes into limp mode until turned off. On starting it is ok again. Seems to happen only when the engine is pushed a little and revs go up. Also the car seems to be emitting a sound like air is escaping  ( almost like the heater fans have been turned up full but it's from outside) read the fault code and its showing P006A. Any ideas? Thanks in advance! 🙂
Code: P006A, Manufacturer: Generic, Description: MAP - Mass or Volume Air Flow Correlation Bank 1
I'd suspect a split intercooler hose.
Ok thanks. Just hoping it's not the dreaded DPF!
Doubtful.
The whooshing noise is typical of intercooler pipe leaks.
