Engine replaced
Hello. I recently had to swap engines due to flooding..it runs ok but instrument cluster only works now and again and several lights are on panel...can anyone advise solution please....cheers
My guess is there's a loose or damaged earth somewhere.  Check the thick earth between the battery and gearbox as a starting point.
Can't necessarily trust the panel lights until the panel is working correctly.  If any are still on afterwards, then we'd have to look into each one individually.
Thanks Tom, I will let you know how it goes...cheers
