Front & Rear side lights not working - RH side only
I have a 2016 Transit Custom, just been for an MOT and discovered the side lights on one side aren't working ( RH / drivers side ), both front and rear.
I have changed both bulbs with new ones and also read that there are separate fuses for both RH & LH sides for the lights.
I believe the fuses are #11, 14 & 15 which control lights on each side in the Body Control unit under the steering wheel. I have removed all fuses and tested them and all are OK. I even removed #11 to double check the side lights on the left went out which they did. Finally swapped everything around with known working fuses and bulbs but still nothing.
Any idea's it can't be bulbs as they are new and also tested in LH side which is working fine. All other lights are working fine.
Thanks in advance.
  • 1 year later...
Same thing with my 2020 awd, did you figure it out. Thanks
Both my front and rear right hand side sidelights both stopped working this morning I’ve done the same as you with no luck either I’m stumped? Dash warning is saying park lamp bulb fault
  • 4 weeks later...
Solved!!!!! Turned out to be shorting on a screw holding the ply lining up. Had to clear fault codes in forscan before it they would work again. Hope this helps.
