Negative Battery Cable
What exactly is the little bit on the negative battery cable? I know it's there for stop start/battery monitoring but what is it?
Is the one on mk7.5's the same as on the new mk8's?
Is a mk8 one compatible with a mk7.5?
Also for regenerative braking on some models.
Two different part numbers listed for up to Feb 2013, then only one part listed, but I'd check with Ford with your VIN/registration.
I've done a bit of reading - Voltage, Current and battery temperature, communicating with ECU via LIN bus.  And a warning about jump starting - never connect a jump lead to the terminal, always check in the vehicle handbook.
That's not related to the battery monitor in any way though as far as I am aware (as they are electrically connected anyway by a short length of cable). The issue is that when a circuit is made by connecting up a donor battery in parallel there can be a spark created which could ignite any hydrogen emitted by the battery. It is never the less sound advice though even if the risk might be small.
  • 1 year later...
my 1988 ford fistiva the red cable is hooked to the negative battery post is thi right
