Brake lights staying on
Hello,
Hoping someone can help.
When I turn my lights on, the brake lights of my 2015 Fiesta ST stay on. I'm thinking this is something that has happened recently because it has been pointed out by 2 different people in the last week.
Any ideas?
Thank you
Check your brake light switch
Looks like a little plunger that goes into a little box with an electrical connector on it. Be in the footwell on the brake pedal
Disconnect it and if your brake lights go out that's the problem, either a faulty switch or it's not triggering correctly, I don't know if these are adjustable in our cars
Check it first and go from there. If it's the switch it's easy to test the switch, just plug it back in and operate the plunger by hand
  • 5 years later...
Hi, experiencing the same issue. When my lights are on the break lights also stay on.
did you end up resolving this issue?
Very easy fix if the fault is the same as @LCIOM
Replace BOTH of your brake light bulbs with new ones.
