S-Max 2.0L Fault code P0104 (MAF Sensor)
dear S-Max drivers
Having a S-Max 2.0L with Duratec-HE (107kW/145PS) engine. Recently having the engine light and fault code P0104. Cleared it few times but returns random.
According the analyzer the fault code indicates a problem with the Mass Airflow Sensor. Now who can tell me were this sensor is installed?? I have a manual but this does not show the MAF sensor on this engine type. Which is strange as I have the fault code. Normally the sensor is fitted between Air Filter outlet and electronic throttle unit but nothing to see. Or does this engine use the T-MAP sensor?
So, question who has info on the were abouts of the MAF sensor on the 2.0L Duratec-HE (107kW/145PS) engine?
ATL
Number 2 is the maf. Should be just off your air box
While you are there stick a new air filter in for the sake of a couple of quid.
  • 3 weeks later...
Get some MAF cleaner fluid and give it a good blast. Don't use brake or any other cleaner on it.
