Ford Mondeo mk4 1.8tdci 09 inje
Does the picture from forscan tell me that looking at the engine from front of the car that the 4th injector on the right is needing to be replaced?
Edited by Triggerste
Well it's not a great start.  Do you have any symptoms of a possible serious issue such as limp mode, loads more smoke than usual when booting it, poor idle or a misfire at low revs and low throttle input?
Although it's too early to tell you should be aware that Ford had an issue late 2008 through most of 2009 with a large substandard batch of injectors that were prone to wearing out far earlier than expected.  The issues a TSB (technical bulletin) regarding a software update but the only real cure was replacing the faulty injector(s) with a later version, somewhere on here there's a long thread that details the issue.
Edit - The forum thread can be found here
Edited by 1979Damian
Found the relevant thread url
Yes car driving seemingly ok then bang engine management failure
Have you looked at the forum thread I linked to?  If so, how many of the potential symptoms do you have?
