Fiesta mk2
Hi I have a fiesta mk2 1.1 popular 1986 D-reg with 26000 miles , The clutch seems ok not hard or to soft , when gears are selected in car , there’s nothing feels fine in car , let clutch out nothing no stall or anything so seems to be in neutral still, rods are moving underneath, desperately need help to get this little fez  back on road where she deserves to be all help welcome
Any help out there ??
Have you bought the car like this or was it previously working ok?
Definitely moving the gearstick far enough to actually select gears, it's not getting stuck half way in?  If you're not sure if it's moving far enough, try and select a gear with the engine off and see if there's further movement.
Check underneath to see if one of the inner CV joints is spinning when you select a gear and lift the clutch - if one joint has failed, all the power will be sent to that one so the car won't move.
If it seems to be in gear, with the clutch up and no gearbox movement.  Either the clutch is no longer engaging tightly (weak clutch spring) or there's an internal fault in the gearbox/diff.
Thks for reply , I brought the car from a auction , it’s mileage & condition made me win it , I will get underneath to check this 👍
  • 1 year later...
Any help on this subject please
What have you checked since your last post?
