MOT Question
My sons Focus 1.8 Diesel has a small crack in the rear fog light lens, is that an MOT failure?
If it's showing white light then yes,
You can buy *Lens repair tape* if you don't think you can get a new light unit in time for the MOT.
Its not showing any white light, its just a crack, no holes in it or anything
Unless you get a real 'jobsworth', I would say you'll be fine, at worst, maybe an 'advisory', but once you get the MOT, source a replacement lens from Ebay (used) no need to splash out on fancy Ford prices on such an item...
Yeah was thinking that, guess it depends who you get!
Since it's a cheap fix why take the risk👍
Some of us are risk takers, others risk averse - i would risk it LOL
i don't know if that focus has one or two rear fog lights.
MOT manual says:
only check the right hand side fog light (drivers side). they should not check the other one.
assess damaged or repaired lamps for security colour light output and durability
a lens defect that has no effect on emitted light = not fail
a lens defect that adversely affects the emitted light is a fail.
The MOT manual is on the Govt website for all to see.
But it's difficult to argue with a jobsworth MOT tester.
Years ago I had a car fail on a small crack on a rear light lens, it was easier to replace it than appeal. And if you did appeal I assume they will get their own back the next time you go in there.
It's good to find a MOT garage that does not take the p**s and try to exploit the customer for their own profit. I found one which i used for years and then he retired. Luckily I seem to have found another one. I think it they charge the full price or near the full price (where I go charges £45) then the business is less likely to try it on to get more money eg. they will adjust the headlamp beam free and not charge £25 for 1 minute's work.  If they advertise MOTs at £20 then the business model is likely based on making sure you can't leave without paying more.
This is not a dig at all MOT testers. some are fair, some just are not.
Many thanks for the replies, I will try and get a lens, can you get a lens or does the whole thing need to be replaced? But not sure if it will come before the mot
If you're going to worry it's easier to fix it👍
No idea what car it's for as you never specified - for my car, a 2005 Mk2, this is a new one........ this is a used one!
This is how it's replaced...
The rear red fog lamp on my Focus has a couple of cracks from damage done by the previous owner. There is no white light shining through and no loose bits of red plastic.
It's been through 5 MOT's each with a different tester and all passed.
If you don't like the look of it change it, otherwise leave it alone.
ScaniaPBman.
In this instance, I'd say that's more a case of "being tight as f*ck!" 😁
Yeah i was thinking on similar lines.By-the-way remind us Stephen is that two or three times you have climbed Mt Everest👍
Isn't that what risk takers do?Instead of not changing a light lens 👍
If it's a MK2.5, you can buy a Euro spec lens and red bulb so you get clear lenses both sides...looks tidier than one red and one clear.  :smile:
