Fault code help
Hi all.
I am new this morning and unfortunately looking for help already.
I have the following codes:
P1934
P1935
P1936
P193B
P0500
P0380
U0073
U0416
U1900
Most are defined as speed sensor abs and accelerator pedal faults.
I've read that maybe the speed sensor is integrated into the ABS module, a mechanic of mine originally said he's had 3 or 4 focus mk2 in for instrument cluster faults causing throttle position issues on diesels that he repaired, of course anyone who has seen these codes before, can you remember how the car was fixed so I'm not throwing money at tons of different sensors that might all stem from 1 single fault elsewhere.
All info much appreciated, if I hadn't spent so much on this car I'd just scrap it but its got a brand new clutch and solid flywheel conversion, new clutch master cylinder, new seats, new maf, injector seals done, thats just to mention a few bits I can think of.
Thanks in advance ☺
Dan
