Focus 2015
Help. Please
no key detected,non push button start
try to start car sometimes it starts then sometimes not
thanks
Try changing the fob battery or use the spare fob.
Hi
changed both fob  batteries, ignition switch, still the same
If it's an immobiliser problem it won't be the fob battery as that's only for the central locking and alarm. The immobiliser system uses a passive chip in the fob.
Yeh just noticed he said no push button start.
4 hours ago, Peter jones said:
Hi
Is it original keys? If not you will need a chip programmed.to work with the immobilizer.
Hi yes both original keys. Do I need a second mortgage 😀
7 hours ago, Bobr said:
Is there a battery in the key?
Yes in both
I have this issue, just stick the keys in the compartment behind the gear stick close as possible to the centre console. For some reason the radio signal doesn't work especially on cold days. Car was into the garage three times to get it diagnosed but they just held their hands up so I just use this work around when needed.
