rocker cover gasket
hi all my 2.5t s max rocker cover gasket has just started to leak is the gasket rubber or is it a black paste
thanks
is it diy job have basic tools so hoping to do it myself or does it require any special sockets ?
thanks again
There is no rocker cover gasket as such. The cyl head is in 2 parts with the cam cam carrier/cover the top part. These are sealed together with a sealant. It's a major job to remove the carrier/cover requiring timing belt off and special tools to hold cams in place. Where abouts is it leaking and by how much?
hi when you look in engine bay looking toward windscreen on the corner by front where cambelt is looks little bit wet
