ford focus 2012 coolant level drop
Hello guys,
I have 2012 ford focus. My coolant level keep dropping after every drive.  I got water pump and thermostat change but still. Anyone knows from where or why level drops always?
2 hours ago, Ford 2012 Love said:
Hello guys,
If you are constantly topping up you have a leak worst case scenario blown head gasket.
Have you checked plastic header tank seems to be faults in these with other models - hair line cracks that only start leaking when pressure and temperature increases.
Have a feel in the drivers footwell, if it's damp, you may have a leak from the pipe that goes into the heater matrix. I'm hoping that the above is your fault though, as the header tank is wee buns to fix as opposed to the heater matrix!
